Atap question: Closed loop or open loop?
Old 05-05-2004, 06:56 PM
"All Motor 9 Second club member"
TXCAMSS's Avatar
Default Atap question: Closed loop or open loop?
Can anyone tell me which table shows what loop the PCM is in at a given time? I bet this is a silly rookie question, but I am baffled. Thanks!
Old 05-05-2004, 10:36 PM
SSean's Avatar
with A-tap, the only thing that would really say if you were in open or closed loop would be to monitor the Fuel Trim Cells. If you had EFILive, I believe that tells you if its in open or closed loop mode, could be mistaken on that though
Old 05-06-2004, 12:05 AM
Restricted User
EFILive's Avatar
There is a generic scan tool PID (called {SAE.FUELSYS} in EFILive) that will show you the fuel loop open/closed status. So *all* scan tools should support it.
It will be called something else in AutoTap but it is there.
Look for something like "fuel system status".
The actual SAE names are:
Fuel System 1 Status.
Fuel System 2 Status.
It will report 1 of 5 states for each fuel system.
Regards
Paul
Old 05-06-2004, 07:44 PM
TXCAMSS's Avatar
I sure appreciate the responses. I'll filter through the tables tonight to see if I can find it. Thanks again!
James
