AEM Wideband (what wire to tap into for power source)
Narrow band diagram
http://www.autometer.com/productPDF/1163A.pdf
Wide band diagram
http://www.autometer.com/productPDF/1143A.pdf
Wide band diagram
I just wired my Aem wide band in last week. If you look in the fuse panel on the side of your dash you will see an empty spot that is labeled ignition. I believe it is in the bottom left corner. You can plug a flat terminal in there to get your power. Just add an inline fuse and you should be good to go .
