Installing AFR gauge. 95 lt1
I am buying a 95 z28 friday. Heres the ad. http://neworleans.craigslist.org/cto/4251984956.html
I know the guy selling it. I saw and drove the car. The spray is not hooked up because the bottle is empty and hasnt been used on it since around 2002. I am wanting to get it working again. It is a wet 125 shot. It has all the correct stuff to run it but im getting parts to make sure its safe. I got the mallory 685 box and the msd harness. My next purchase is the afr gauge. I decided on the NGK AFX wideband set up. I read the write up on the install. Does anyone have any tips or suggestions for the install of the wide band/ mallory box, or anything else i should look at getting. The 02 sensors and cats and tuned out. Where is the best place to mount the wideband. Ive read put it where the 02 sensor goes. the merge. the left side or right side. everyone said different places. Thanks for any help.
the manifolds are stock. its got the SOTL exhaust. Ill be sure to check for leaks. I couldnt find a safe AF range for the lt1 when on spray. whats the range i should be looking at reaching
Even if they "click" they may be unreliable. No need to replace, only cleaning and inspection of the plunger, seals and springs is enough (replace any worn or damaged parts)
http://www.coldfusionnitrous.com/dvd...OIDMAINTBB.wmv
how easy are that to service? nvm. just saw that video lol. hope i can find the seals if the one in the fuel solenoid. i know its a older system
the mallory 685 box is coming tomorrow and im getting the car saturday. Bout how much timing should i set the box to pull. I read 2 degrees for every 50 hp shot. or was it 25?? but some said thats not always true. but is it a good starting point?
