LS3 dead-zone in throttle response
Old 03-09-2014, 01:31 PM
efnfast's Avatar
Default LS3 dead-zone in throttle response
I'm using the GMPP LS3 wiring harness for their crate engines (LS3 525). Tuned with HP Tuners.
If I just feather the gas pedal (e.g., push it 5-10% of the way down) there's a complete dead zone, meaning the rpms don't do anything. It's not a delay in response, it's a complete dead zone (I could push it 5-10% of the way down and hold it there for an hour and nothing will happen). So far I've gotten around this by pre-loading the gas (I know, safe, lol), but this year I'd much rather tune that out.
Is that a common problem and an easy fix (some table that says don't open the tb until x% of the pedal travel has occurred) or something that's peculiar to my setup? (this is obviously dbw, not cable operated throttle)
Old 03-09-2014, 01:40 PM
Old Geezer's Avatar
Posting the data logs and the tune file, is a start.
Old 03-09-2014, 04:11 PM
efnfast's Avatar
Don't have either, lol, I'm just wondering before I start down this path if there is a place in the tune that would control how much the pedal has to be pushed down before the throttle begins to open
Old 03-13-2014, 09:32 AM
JetMech442's Avatar
On my ls1b, I have a table that correlates pedal movement to blade opening. I'm pretty sure your ecm had the same thing
Old 03-14-2014, 04:36 PM
efnfast's Avatar
We found it - there is a pedal position vs throttle opening area, and until 9% pedal travel I'm at 0% throttle.
However, the table has a warning that changing these values may fry the ECM and TAC.
W-TEEEEEE-EFFFF?
Now to try and figure out if that warning applies to stupid changes (like 50% throttle open at 3% pedal travel) or any changes :/
Old 03-14-2014, 06:36 PM
Old Geezer's Avatar
Take a look at www.efilive.com
It was hashed over, al length, on the EFILIVE forum.
Quick Reply: LS3 dead-zone in throttle response
