can someone share they're 102/102 idle tune
Super Hulk Smash
Just do a compare and change the values in the idle airflow section. As long as your fueling and spark are close, it should idle if your throttle body is open/closed enough. I have mine set to open at .47v. But it's a FAST with a smaller IAC port. If you have a NW, you may need additional tweaking.
