LS1 Shuts off WOT, sometimes with backfires
So my truck has been shutting off at WOT lately. And last night i showed a friend how it does it. I was peddling through 2nd gear and when i put the pedal to the metal after peddling and it shut off and back fired about 3-4 times, people said they saw flames come out the exhaust for everyback fire. My friend said its a ground problem, anyone have another idea on what it could be before I get into it? Thanks
Hey did yours actually cut off at wot? Because I have the same problems but this happened after a "tuner" got his hands on my car going in for a dyno. I think something he tweaked in the tune is causing my problems but I flashed my original mail order tune but it's still doing it. Once I go wot it will shut off like I turned off the ignition. I posted the data log on hptuners site the folks there said my maf and injectors are maxed out at 5000rpm. I can understand that but don't get why it didn't do it before taking it to the dyno? I am local too in Maryland if you understand hptuners I can really use some help
Don't know the fuel pressure, and i put another ground and voltage seems to be great bur it still shuts off at WOT. Scanned it and nothing came up... Getting really frustrated
Any ses codes? I don't have any
I also tried running mine open loop with the 02 sensors disconnected it still shut down and still runs pig rich. Mine will cut off in any gear or speed doesn't matter if it's in first or 3 rd gear as soon as I go wot it dies
Frustrating indeed
What are your mods? maybe your maf is maxed out like mine
Frustrating indeed
its a ground problem. If it acts like you turn the ignition off and comes right back to life you have a loose ground or something is arcing.
mine was that i had my catch cans in a way that when the motor hit full boost and "twisted", the catch cans moved just enough to tap the battery and short everything.
A few months ago, i had the ground wire on the back of the heads break off the bolt and the car started acting wild.
Does the car shut-off completely, as in you have to use the key to restart it? Or does it just break-up, pop and stop accelerating? If so, you probably have something contacting the exhaust and/or you're having false knock-retard. You need a scanner to log what's happening when you drive.
Okay, so i did some test runs,,when i did my 1st run it shut off at the end of 3rd, i let the rpm drop all the way then i restarted it and it started up fine...after that i did 3 more runs and it didnt shut off...I turned it off for an hour and i decided to do another test pass after having it off for an hour and it shuts off at wot again...
Check your battery, make sure it's not rocking and touching the ac condenser bracket or condenser itself and shorting for a moment. Under acceleration it might be sliding back or rocking enough to touch. When the power cuts of it starts to decelerate allowing the battery to slide away. Other things to check are all ground connections like others have said. Since it fires right up we know it's not flooding the engine at wot so fueling doesn't sound like an issue. You most likely have a short somewhere. Check battery, check ground cables, looks at your exhaust and see if any wires are close enough to touch and are burned. Follow the positive cable and look for any spot that the rubber shielding is worn and may be allowing bare wire contact. Do this for the negative side cable also.
Good luck.
Good luck.
I have the same problem I did change the crankshaft postion sensor,still does the stalling.The car starts fine no issues just when I start going down the block its starts to stalls n dies .my car is a 01 Camaro ss the only mods it has are long tubes .eney ideas
Also:
The CKP reluctor may be loose (spins on the crank when crank accelerates).
Check battery cables, if positive and negative main cables are routed together in the same convolute tubing, then they may have rubbed thru each other (and short together when acceleration g-force pushes them together)(example of this is LS1 F-car).
Alright guys, i finally fixed the problem. It was the crank position sensor connector. It wasn't connected all the way in, i barely pulled the connector and it came right off... So i connected it back in all,the way and put a ziptie so it wouldn't get loose or something. Did 3 test passes and it,all went good thanks everyone!
