oil pressure and fuel level gauge needed?
Old 05-27-2004, 12:55 PM
2001CamaroGuy's Avatar
Default oil pressure and fuel level gauge needed?
Does the computer NEED to see them in order to work? I'm installing aftermarket gauges that will have their own sending units and I'm wondering if I can remove the factory ones (cleanup). Will the computer freak out if they are gone?
Old 05-27-2004, 02:44 PM
horist's Avatar
nope... PCM doesn't give a rats ***...
actually I don't think either of them even go to the PCM... i know the oil sensor only goes to the gauge cluster on F-Body's (PCM doesn't know what the oil pressure is) the fuel level gauge may go to the PCM (because I think there's a fuel left value you can watch) but the PCM won't care if it's showing as empty
worst that will happen is you'll have an eternal Check Gauges light on
Old 05-27-2004, 04:07 PM
Sweeeeeeeeeeeeeeettttttt!
Old 06-01-2004, 11:42 AM
John_D.'s Avatar
I thought you had to see oil pressure for the fuel pump to activate. (other than the initial key-on pump cycle)
Old 06-01-2004, 12:27 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
I'm wiring up a FAST standalone, and we stripped my oil pressure gauge and wiring out of the harness and we are going to repin it into the connector in the passenger side footwell. I have to reground it though that was wired into one of those big multigrounds in the harness.
