Help -No Gas - will not Fire?
Okay... I posting up for a buddy. I am Carb LSX guy...so I am not pro or even understand much with the GM FI system. The harness is aftermarket not sure the brand.
Car 69 Camaro with 6.0 Iron block with AL LS3 heads and LS3 intake and fuel rails -guessing a Camaro intake and rails. T-56 tranny.
The computer VATS was reset so we can rule that out. The injectors have 12 volts... the fuel pump works and we have 60psi at the motor. Motor spins over strong.
The Bad...
Plugs are dry.
Even when we spray fuel in the intake through the throttle body it doesn't start?
Any ideas on where we are start? Thanks!
The Bad...
Plugs are dry.
Why would you tell someone to do that? They can get a severe shock and if the person should happen to have a medical condition they could end up in the hospital or worse.
If you want to check for spark you can just leave a spark plug on the end of the wire and have someone turn over the engine. Or go buy a cheap spark tester that goes between the spark plug and wire.
You're no fun. I'm going to guess you don't check 9V batteries by touching them to your tongue. Relax. I was just telling him to check for spark since he said it didn't even hit when they sprayed fuel in the intake. And if he would actually test for spark that way then, well...............
I suspect he has both a fuel and spark problem.
Lol. the screw driver trick works for spark....we will check that but i believe it's fuel. Can't even smell gas. Just think injectors are not firing. Checking ground is a good idea... but we see 12 volts on the injectors.
Yea it sparks good. I checked the grounds but can check again. And I have 12v to the injectors with the switch on. Bad injectors?? I hooked up a scanner and it shows rpm when cranking.
thx guys...
