cold start issues and possible vacuum leak.
So I need your guys help I have the ftp 104mm lid and 102mm throttle body, 96mm intake, sd tune. When I start up it idles to 2k for 10 seconds and then comes to around 800-900 rpm is that normal? Also when I go after starting my car I can push the gas and the car will not move, it will just hesitate and then like 5-10 seconds later it will act normal and go. After the cold start when driving to work I can floor it and it will have a hesitation and then will actually go to open throttle a few seconds later. what could be my problem? if you need more info on the car just ask.
Update now I started it to go to lunch and it it idled around 600-700 rpm and every time I pushed the gas it would die. Also I let it sit for couple minutes then it when to 800 rpm. Then it acted fine when I pushed the gas. So I drove it then I tried flooring it and it would hesitate and actually never go wot. What could be wrong?
