Programing a/c compressor
Swapped a gto p59 into my 2000 camaro and changer the ac as analog in hptuner. The blower will turn on but the compressor does not run. When you change ac types in hp does it also change the compressor type to the right kind? I started with a ctsv tune and the ctsv normally has a fixed compressor and the camaro and gto have a variable. Could that be the problem?
Did you wire it as a variable compressor using a pressure sensor or as a fixed compressor using low and high pressure switches?
Did you try switching the platform type matrix to one that runs the correct compressor?
