pinout per connection on 411 pcm 2002
those anyone have the pin out per connection chart. i have the pin out chart but was looking for one that shows what pins are for every sensor with out scanner through the pin chart. i made one when i was clipping the pins but lost the paper.
i already have this chart
http://lt1swap.com/99-02_vortec_pcm.htm
I have no idea what you are trying to say, but see if this link helps.
https://ls1tech.com/forums/conversions-hybrids/1757231-ls1-0411-pcm-wiring-diagram.html
sorry . i was talking but pins for sensor(connection) i order. i still have some of my notes when i was removing the pins. knock sensor pins 11,51 blue connector. crank sensor 12,21 blue connector. maf 25,31,57 red connnector. , coolant 41,74 blue connector. icv ,76,77,78,79 red connector, tps 24,54 red connector. so so on. the is some that lost. i was just looking for a chart like that. it is just easy to read like that
thanks
i just got homw and open your link. that should work. thanks
