6L80 Trans lock up wiring issue - need help
I have an L76 motor and 6L80 trans, all out of a Pontiac G8. I bought a PSI wiring harness. They had to make one because they were not doing a standard 6L80 harness back then (2 yrs ago) when I put it in. So I'm all done and ready to drive but I noticed my brake lights staying on. I checked the two purple wires for the Converter lock up and 1 wire has 7 volts on it and the other has 9 volts on it. I called and talked to PSI and we checked and made sure the wires were right and a few other things, but can't figure out what is wrong.
The only solution they have is for me to pull the harness out and send it back. Before I do this, does anyone have any ideas of what may cause this. Could it be caused by the tcm or pcm tune or anything else?
Any help would be greatly appreciated - If I pull this harness out it is going to set me back a month.
Thanks
Thanks
Do you know for sure that you have the wires connected properly to your brake switch itself?
I realize you are using a PSI harness but of course wiring is wiring. According to Speartech's instruction page on hooking up brake. ''LT. BLUE (PPL in your case)
To brake light wire at brake switch. 12 volts when brakes are
applied. (Used for transmission/torque converter info).''
http://www.speartech.com/v/vspfiles/...ns/LS58X6L.pdf
To make it easier on your self tie both of those PPL wires from PSI harness and then take a single wire to the brake switch.
On an E38 ECM Pin 9 on X-1(Black Connector) should be 1/2 brake switch wires and other comes from the Black round connector on 6L80.
The 6L80 brake switch wire should be located in position 6
Thanks for responding - the wires are in the correct pin locations. One is on pin 9 on the black connector on the ecm and the other goes to pin 6 on the trans connector. I ohmed them out and they are in the correct spots. I did have the two purple wires soldered together to a single wire going to the brake switch and they were wired 12V when brakes applied.
