been play with HPtuner
Moderator
I would say no, your O2 sensors are not working.
Even tiny changes in the AFR will cause huge changes in the narrow band sensors; mine are constantly swinging from e.g. 100mv to 800mv.
i dont know what cfg file is , i will work on that here are 2 log runs i just did , i did get a engine light on the first time i cleared it , never came back on ,,
hope this is it
hope this is it
#38
the code are PO134,, PO154 i have been reading about these, and most say change the sensor, mine are new i put them in when i did the motor swap , reasoning being the old sensors were different plug , i had to go to square plug to match wiring harness , could that be something in common ??? the motor is from a 06 truck and PCM is from 02 camaro i say the harness id for the 06 truck .. what do i need to do ?
thanks
thanks
#39
A 06 truck is DBW. are you running DBW? The O2's are wired different on a truck vs camaro harness. You can repin the wires for the O2 sensors to make it work or change the tune to a truck tune and they will work if thats your issue. You're going to need to get a camaro schematic and a truck schematic and see what harness you have first.
#40
06 truck motor but i have DBC , the harness was order for the PCM ( 01 camero ) i have red and blue connectors
thanks
thanks
