hp tuners afr error histogram
Old 09-28-2015, 05:44 PM
mikesimpalass's Avatar
Default hp tuners afr error histogram
hi,
I'm trying to tune my ve table using hp tuners, but my afr error histogram doesn't want to populate.
I have hp tuners standard, and I'm recording my wideband voltage through ac pressure. which shows afr in my table display, and I also made a custom afr error pid, which works and displays afr error in my table display.
I changed the standard afr error histogram in hp tuners to accept my custom pid instead of using the pre programmed pid. and I also added a filter to filter out commanded afr less than 14to 1 afr
Old 09-28-2015, 05:50 PM
any idea why my afr error histogram won't populate with values?
Old 09-28-2015, 06:08 PM
Drj8787's Avatar
All the sensors or pid that are in the function have to be in the table also for the histogram to work u prolly forgot the commanded afr in the table. Add that and see if it works
Old 09-28-2015, 06:22 PM
I already had afr error in my table, and it's working in my table. just not recording in my histogram
Old 09-28-2015, 07:02 PM
Drj8787's Avatar
u miss understood me you need the COMMANDED AFR in ur table also seeing how that is what [SENS.121] is in the function for the the AFR ERROR. Like I said every sen or pid that's in the function formula must be on the table
Old 09-28-2015, 07:17 PM
Drj8787's Avatar
Here's a screen shot of my table wideband2 is my custom wideband PID, egr postion becuz I log through the egr so have to have that for wideband PID to work, where I'm pointing is COMMANDED AFR which u have to log for the AFR ERROR to work.
If u insert the Commanded afr into the table id almost guarantee will start working
Old 09-28-2015, 07:28 PM
Drj8787's Avatar
This is what I have in my table for it to work I don't know is the low res on makes it work also or not, it should tho just uses less bytes
Old 09-28-2015, 07:46 PM
Drj8787's Avatar
Post ur config file and custom histos or screen shots of them, the table and the function formulas for ur custom PID. If what I sugguested didn't help
Old 09-29-2015, 10:28 AM
Drj8787's Avatar
Get it working?
Old 09-29-2015, 11:59 AM
still not working,
here is a screenshot of my table and custom histogram.
Old 09-29-2015, 12:15 PM
and I am actually using low res commanded afr, maybe I should switch to high res? thanks for your help
Old 09-29-2015, 06:00 PM
is there something wrong with my filter string? I removed it and everything seems to be working now.
Old 09-29-2015, 07:48 PM
eaglegoat's Avatar
You were filtering everything greater than 14.
Quick Reply: hp tuners afr error histogram
