Poor idle needing help
Old 05-04-2016, 03:22 PM
Twinchargedlsx's Avatar
Default Poor idle needing help
When I first start it the afr is a little rich but after a minute or so it goes Way lean into the 17+ afr and my fuel trims are around -30. What would cause this?. Thanks guys. heres the tune and log
File Type: hpl
File Type: hpt
Old 05-04-2016, 08:49 PM
Also if I command a 14.7 afr in the scanner it's idles and runs really well but once I turn it off it begins climbing to the 17 range?
Old 05-04-2016, 09:07 PM
outkast6991's Avatar
Is the car tuned? What's the setup?
Old 05-04-2016, 09:25 PM
No I'm trying to get a base tune first. And it's a twin charged 416 all forged engine with 609 and 628 lift cam. The last engine was the LSX376 b15 engine. It was speed density tuned as well. But the new engine is bored and has a 4inch stroke.
Quick Reply: Poor idle needing help
