6.0l L98 E38 ECM + fault codes: No start or run
I’m having a really tough time getting this thing to run after a swap to BMW chassis.
I’ve scanned the ECM and have double checked all wiring - verified the positive and ignition wires to the three terminals, ground is present and installed the 100 ohm resister to X1-52 to starter relay as suggested elsewhere on this forums. Don't think anything needs doing, or am I missing something??
My fault codes are –
P0807 Clutch position sensor Circuit Low
P0230 Fuel pump primary circuit malfunction
P0463 Fuel level sensor circuit high input
P0268 Fuel level sensor circuit low input
I’m guessing the start/r run inhibit is to do with either of the first two codes, assuming of course VATS have been effectively disabled by my mechanic??
I’ve wired three external relays - fuel pump, start and main relay.
Any thought welcome please as I'm new to the GM platform and am about to put a match to this project.
Thanks!!!!!!
Thanks!!!!!!
Thanks for the reply, I had thought VATS but having paid for it to be disabled, started doubting myself to have done the obvious. I've emailed the tech, he is coming round next week to have another look at it. I'll post an update - hopefully we get it running.
Is it starting....runnning then dying? Or not starting at all?
Not running at all, there is no spark. I've wired the starter relay through the BMW DME to retain some security and atm the fuel pump is simply wired to IgnV but I'll move it to the ECM fuel pump output X1-50 when it eventually runs...same for the main relay control.
I've got 12V on X1-52 Starter Relay Coil Control, but 0V on X1-50 Fuel pump and X1-59 Main Relay Control...
Thanks for confirming these fault codes wont inhibit running - its restored a bit of my sanity!!
The tech is coming out next week to hopefully get it running. I'm pretty sure now that it is VATS related...
It should start even with vats enabled, but it will shut off in a few seconds.
Is your switched power to the ECM start/run or accessory switched. If you grabbed that signal from inside the cab, most of the time accessories will switch on, but shut off during cranking to aid battery power. So check this circuit while the engine is cranking.
IF this is happening, your ECM is shutting off during cranking, hence it won't start. (Ask me how I know ).
Also. Check my recent thread for the steps I went through to solve my problem. I just wasted many hours on this, so I know what you are going through.
https://ls1tech.com/forums/conversio...won-t-run.html
I bit of feedback - this comment had me thinking that it may be something else so I decided to recheck everything I had done...I found the two sensor wires for the BDW had been swapped over.
Strange the scanner did not pick it up as a fault. I guess the lesson here is not all scanners are created equal!
I now have a decent tool to replace that cheap eBay Elm scanner.
The wiring solution for the E38 ECM to E46 DBW pedal (in case somebody else needs it):
A - Low Reference sensor 2 (X1-23) PUTO BMW PIN 1
B - APP Sensor 2 Signal (X1-32) TO BMWPIN 6
C - 5-Volt Reference 1 (X1-56) TO BMWPIN 5
D - Low Reference sensor 1 (X1-30) TOBMW PIN 2
E - APP Sensor 1 Signal (X1-29) TO BMWPIN 4
F - 5-Volt Reference 2 (X1-36) TO BMWPIN 3
Thanks all for the useful input!!
