Engine shuts down in 20-30 seconds
I have a buddy that installed a LS1 into a street rod. He is having a issue where the engine starts but shuts down in 20 seconds.
He is missing the theft deterant unit. Does the wire that goes to the pcm have to be grounded?
Also his fuel pressure is at 84 psi. Could this also cause the problem? Does the pcm monitor this?
Thanks,
Roman
Thanks,
Roman
Originally Posted by slow
20 seconds is weird, vats normally kicks in about 5 seconds later
fuel pressure at 84 is too high, the pcm does not monitor the fuel system
the wire for the vats, needs a 5 volt 50hz square wave signal
Ryan
Ryan
Thanks
Originally Posted by romanss
It's almost like they want to make it hard or something.
Thanks
Thanks
