My car has never been Autotap'd, having someone do it, what do I look for?
The car has the mods below, has been ran at the track, but has never been Autotap'd. It has MTI tuning, but hasnt had a tune since April of '03. I personally dont know how to use it, muchless know what needs to be done, but Im going to find someone local who can do it, and I wanted to know what I need to look/watch for. I wanna make sure that the car is where its suppose to be. Back when I ran the car at the track last, which was in May of this year, I wasnt running the times that I should/could of been with the mods that I had, and lots of people were telling me to Autotap it. Can you make any changes with Autotap or is it just a tool that tells you where the car stands? Anyhow, let me know, thanks.
Fast Toys ram air kit
K&N air filter
Texas Speed & Performance air lid
Granatelli MAF
SLP high flow bellow
Bauer Racing ported & polished throttle body
LS6 intake manifold
NGK TR-55s
Holley 9mm wires
Kooks 1 3/4" long tube headers
Custom 3" true duals w/Dynomax bullets dumped
ASP underdrive crank pulley
Meziere electric water pump
MTI C2 cam (224/.581/112) plan on changing cams, but dont know which one
Manley valvetrain kit
Billingsley ABS delete
Century 200-4R w/all options
Yank SS4000 soon to swap over to a PT4400
TCI flexplate
Hal shocks in a 4 corners w/R series in front
Spohn-LCAs, PHB, TA, SFCs, & 25mm rear sway bar all in chromoly
BMR-K-member, upper & lower a-arms, & relocation brackets
Airlift airbag
Denny's nitrous ready driveshaft
Strange 12 bolt w/4.10
Bogarts-15x10/ET Drags 15x4/165R
Wolfe chromoly 6 point weld-in roll bar
Weight reduction
K&N air filter
Granatelli MAF
LS6 intake manifold
NGK TR-55s
Holley 9mm wires
TCI flexplate
Airlift airbag
Weight reduction
Moderator
ATAP is "look, but don't touch".
You will have a limited set or params you can pull
at one time. What to choose, depends on what
you are chasing. I have PID sets I prefer for
trans issues, for misfires, for general running-
around.
What are you most interested in knowing?
around.
jimmyblue: I dont know what Im looking for, that is what I wanted to know. Back when I posted about my times and my mods, I was getting a lot of responses to Autotap the car, but I dont remember anyone saying what exactly to look for. So in other words, it only shows what the car is doing and cant make changes? It will only tell you so many things at one time? Again, I dont know what Im looking for, I just wanna be sure that the car is running top notch for best results.
Moderator
My "general" PID list I use is something like
Vehicle speed
RPM
TPS
MAP
MAF lb/min
Volumetric Efficiency
Dynamic Cylinder Air
Spark Advance
KR
Knock Learn Factor
Fuel Air Multiplier
Injector PW B1
HO2S B1S1
LTFT B1
Fuel Trim Cell
Delivered Torque - Engine
That all fills up my 24-PID "rack". Older versions of
ATAP I think could not hang with 24PIDs x 10 frames
per second, though EFILive and HPTuners do. So you
may have to compromise on params or rate, or not.
Vehicle speed
RPM
TPS
MAP
MAF lb/min
Spark Advance
KR
Knock Learn Factor
Fuel Air Multiplier
Injector PW B1
HO2S B1S1
LTFT B1
Fuel Trim Cell
