tach off by 300, how can I fix it?
Old 10-26-2004, 09:28 PM
Terry Burger's Avatar
Default tach off by 300, how can I fix it?
My PCM reports 800rpm, while the tach reports 1100rpm. How can I fix that?
Thanks,
Terry
Old 10-26-2004, 09:43 PM
robertbartsch's Avatar
weird?? Is this at idle?
Old 10-26-2004, 10:36 PM
slow's Avatar
same problem here. 800 1100 shown
i don't want to mess with the needle, but thats the only way i know to fix it.
Ryan
Old 10-26-2004, 10:42 PM
87GMC's Avatar
same here on my 98, i thought i read somewhere thats how all the 98 were
Old 10-26-2004, 10:55 PM
LS1TECH Sponsor
Magnus's Avatar
Pull the gauge cluster out, then remove the clear cover, then put the gauge back in...
pop the tach needle off.. use a scan tool to hold the rpm's at 1000 rpm or 2K rpm.. put needle back on.
I did this to my car and it worked like a charm.
Old 10-27-2004, 10:37 AM
GuitsBoy's Avatar
If you turn the key to run, but dont start the motor, the tach spindle will zero out. No scan tool needed.
Old 10-27-2004, 11:39 AM
Great ideas guys! Thanks
