Got a P1133 Trouble code
Old 10-31-2004, 07:07 PM
42NightZ28's Avatar
Default Got a P1133 Trouble code
From the OB2 site That basically says that its the problem lies in sensor 1. Is sensor 1 the sensor that is on the driverside manifold?
Old 11-01-2004, 09:51 AM
Bill Bowling's Avatar
Talking
P1133 is
HO2S Insufficient Switching Sensor 1
Sensor 1 is front pass side. Could be a bad sensor unless you have LT's.
Bill
Old 11-01-2004, 09:55 AM
Go to this search:
https://ls1tech.com/forums/search.php?searchid=878219
Good luck.
Bill
Old 11-02-2004, 11:06 PM
42NightZ28's Avatar
I have the Air/Fuel Gauge hooked to that side with the pigtail, I will remove that and see if that does the trick
