Need help with predator tuner
Down loaded a tune from my predator tuner everything was fine until I went into perameters and then everything went crazy, I tried reseting the pcm by disconnecting the battery but nothing happens, I cant even down load my stock tune, any ideas before I call diablo sport?
Moderator
Leave the battery connected but pull both of the
PCM fuses. That may reset a bus hang. Also check
that your cig lighter fuse is still good, if the problem
is that the Pred is just dead (vs alive, but no go).
