Ditching the stock PCM?
I'm intrested in ditching my stock PCM, what are some of the good aftermarket alternitaves?
I would like something that will work with twin MAFs.
Has anyone here ever made their own? The only hard part would be making interface boards to read the sensor data and shoot it into a linux box, other than that writing the code would be pretty damn easy).
It depends on how much you want plug and play integration. Accel has a unit that is plug_and_play; BS3 is another one that is plug_and_play for the LS1's that has been getting a lot of praise. There are many other alternatives that I would prefer personally such as Electromotive and Autronic but these two would require a good bit of splicing and the stock gauges would be out of the picture.
Their is a couple of Open Source and Closed Source DIY EFI Systems out that you can build or have them build and you can tweak the code at will. None are Linux based as they don't run an operating system per say. It is all low level assembler directly booting the microcontroller. I would highly advice against trying to roll your own. I would pick up one of the DIY projects as it will save you more time and trouble or just buy one that you can get a base calibration to get you started for your engine. Autronic has an “Auto-Tune” feature which almost eliminates the keyboard input required to get your car dialed in.
Originally Posted by Bryan Wilkinson
What is it that you think the stock computer will not do that you need it to do?
Also, intigrated boost, nitrous, and fuel control stuff would be nice if I were to work out a custom PCM.
I don't think that Matt's is really a 'stock' computer as most people think of one. You need to understand that he can do things in there that 99.99% of other people simply cannot...I heard somewhere that the computer he is using is a 2005 C6 prototype. Maybe he can clarify though.
I have heard rumors that the HP Tuners guys are working on a solution that will allow the stock computer to work with a 2-bar MAP. That would offer the ability to tune with some amount of 'boost' accomodation by the PCM.
If you are set on an aftermarket solution then I would strongly suggest BS3...seems like the limited number of people that are using it are having very good luck with it.
Don't forget the MEgasquirt... will do anything a BS3 unit will do (except for sequential, it's in development now) for 1/5 the price...
Nope, stock box. Lot's of keyboard time though. C6 box is a completely different animal.
And yes, I talked to Keith at the shootout earlier this month. They got a 2 BAR based speed density hack working and he was trying to get me to play with a proposed 3 BAR setup.
They might be some solutions to keeping the cluster working w/ a stand alone coming, but for now the HP tuner setup might be the best bet to keep the rest of the car happy. No MAF to worry about then.
LS1TECH Sponsor
Harlan, it was great talking to you about it.. I think you'll really like the quality of our 2 bar setup. I can't go into all the details about it but we cover all the bases with the modification.
We have cars running our 2 bar setup right now and hope to have our public version available for purchase in the near future.
You'll be able to remove your MAF and run in Speed Density mode with boost reference now that you have a 2bar MAP sensor. You can add fuel via lbs of boost as well.
We'll have more information VERY soon.
Thanks!
- Keith, HP Tuners
Thanks!
- Keith, HP Tuners
Keith,
Question on your 2 bar setup, I'm not interested in ditching the maf, But i am wondering if the 2 bar map will allow the computer to know the pressure drop across the injectors is droping under boost? If so this will save me the expense of installing a boost/vac referenced fuel system.
Ryan
Ryan
In all honesty, the best way to setup the fuel system is with a manifold referenced regulator.
Keith, you'd have to figure out something more than a 2 BAR before i can play with it I'm actually gonna be using an extra fuel pressure gauge sensor to log boost now. A 3 BAR ain't gonna cut it anymore
