03 PCM and Electric Fans
Guys,
Getting ready to install the 05 Electric Fans in my 03 Truck. Gonna control them with the PCM via Nelsons 3 relay wiring harness. I've read that the 05 PCM's don't turn the fans on above certian MPH's. Do the 03 PCM's have the same logic? Looking at HP Tuners appears I have the capability to control the 2 fans independant of each other. Fans Stage 1 and Stage 2. With Setpoint temps for each.... Also a min and max mph. I am not seeing how you control 2 fans independant of each with just one output. Pin #42?
stage one and stage two is just a high and low settings. I have seen nothing that turns the fans off at a certain mph on hp tuners. HOwever, I have my ac cutting off at 5 thousand rpm's. Thus, As long as my ect is lower than what I have in the program, my fans will cut off as well above 5 thousand rpms.
