vats light on not flashing will not start just got removed
I just got my computer back from texas speed. the first day I started it once the car ran great and no problems at all the next day which is today The car will not do anything but the securtity light is on steady. I wanted to take the car to the track sat. but doesn't look good now. I tried waiting 15 min and that did not work. I tried unhooking battery and making sure pins are in comp. good but still no luck. they removed vats in the tune. is there any way to bypass the vats to get it to start. anyone else had this problem. it is a 98 a4 z28.
9-Second Club
Good luck, Ed
bcm pinouts to bypass the vats if it is dissabled in the pcm, c11 yellow/ black, it gets a ground when the key is turned on, that will allow the starter to work, if you dont want the security light on, cut, c12 its grey. if you want to bypass all the vehicle harness with a resister, measure the key, and then jumper pins, c2 purple white, wit the resister value to wire d7 white black,
