lt1 -ls1 coil per cylinder conversion
Old 01-19-2005, 10:28 PM
1qwklt1's Avatar
Default lt1 -ls1 coil per cylinder conversion
I am runing a 396 with afr 220s solid roller with stock pcm with ed wright tuning am having a problem with car braking up in higher rpms for a split second looking for any buddy with any info on benifits or personal experience with this conversion.Am looking for a kit to buy for this conversion any info thanks.
Old 01-19-2005, 10:36 PM
horist's Avatar
when it comes to LT1s I'm clueless... but I copied this to the LT1 section too... so hopefully between the two sections you'll get an answer
Old 01-19-2005, 10:47 PM
wait4me's Avatar
hmm,, this might kinda be cool, an ls1 computer, lt1 harness repinned, and the coil wires run in the stock harness? hmm.. ill try to help you on this one if you would like, email me tommarrow and we can talk, jes
Old 01-20-2005, 07:33 AM
slow's Avatar
how are you going to get the crank/cam position sensor from the lt1 motor?
making an opti work on a ls1 harness?
Ryan
