VE tables effect WOT?
Old 01-22-2005, 11:16 PM
John02SS's Avatar
Default VE tables effect WOT?
When I was dyno tuning my car I had a file with my stock VE tables tweaked I was using, but did my PE tuning on a file that had a tweaked Z06 VE table by mistake. Will loading the correct VE table back in the car have any effect on my WOT A/F or jus the part throttle? I read that the VCM uses the VE tables for < 4000 RPM's and steady load > than 4000 RPM's is strictly MAF based. With this in mind I would think the different VE tables would have no bearing on the PE values at WOT, but I'd love to have some input. The tunes are identical other than the VE tables. Thanks fellas!
John
Old 01-23-2005, 08:52 AM
wait4me's Avatar
yes, ve effects fueiling at wot, the pe vs rpm is an adder of the ve tables 14.7 af ratio. it uses the ltrims to set up the 14.7 then pe table to add the fuel from there.
Old 01-23-2005, 10:28 AM
John02SS's Avatar
So I should tweak the low rpm points in the Z06 table that I loaded by mistake to adjust for the cam and leave the rest alone since the car is tuned PE wise with this table.
Old 01-23-2005, 10:38 AM
Another_User's Avatar
You could do it that way. Or you could tune your VE table and just make sure your PE table is putting you rich if you reduce the VE table near WOT. If you make increases it won't matter. After you are done you can adjust your PE table to put your WOT AF ratio back to what it should be. If you want to go the extra mile on your VE tuning, you can turn off PE while you do it, that way you get the proper trims across the board. I personally don't do that because I don't want to run my car too lean at WOT. I can hit most of the VE table without going into PE mode anyways.
Old 01-23-2005, 10:46 AM
narcszm's Avatar
Overwrite the values for all MAP pressures and 400-3600 RPM with your stock VE tune. I'm assuming you did a speed density tune on your stock VE table. Leave the ones 4000 and above alone. Select values 20-55 kPa and 3600-4400 RPM and do a polynomial smoothing about those values. Select values 60-105 kPa and 3600-4400 RPM and do a polynomial smoothing about those values, also.
That should pretty much put you where you want to be.
Old 01-23-2005, 11:50 AM
I haven't had good luck with smoothing. Hand smoothing has worked out much much better for me.
Old 01-23-2005, 06:20 PM
John02SS's Avatar
narcszm,
That is pretty much what I did. Went in and adjusted the values under 4000 to what they needed to be and left the ones about the 4K mark the way there were so the WOT fueling didn't vary. Thanks for the input!
Thanks guys! Man HP Tuners makes this **** easy! Copy, paste, and your back in the game!
Quick Reply: VE tables effect WOT?
