Question about idle
Old 03-15-2005, 10:26 PM
Devilss02's Avatar
Default Question about idle
I had a torque converter installed last summer and since then its idled at a low rpm. It still drive fine but stalls out sometimes. I was wondering if u can have the idle raised by using ls1edit or if i should just tap the throttle body hole bigger. thanks for the help in advance
Old 03-15-2005, 10:42 PM
AnthonyR's Avatar
A bigger blade hole is not going to increase your idle, you can only do that via editing the PCM LS1edit, HPtuners etc...
Old 03-15-2005, 11:16 PM
LS1TECH Sponsor
foff667's Avatar
you could try adjusting your set screw and then resetting your tps...this might give you just enough play.
Old 03-16-2005, 02:33 PM
Bill Bowling's Avatar
Talking
When I have my stall installed I raised my idle by 100rpm using LS1Edit.
Bill
Old 03-16-2005, 04:07 PM
SmokingWS6's Avatar
Have you disconnected the battery since the converter install? It might need an idle relearn. Before I let it do an idle relearn it would idle too low.
Old 03-16-2005, 04:16 PM
2001NBMZ28's Avatar
Had the same issue, got the in gear idle increased 150 RPM - hasn't died since.
Old 03-16-2005, 08:35 PM
Devilss02's Avatar
I have, but once it learns the idle its the same thing and about putting it in gear it does go up a lil but it stalls if you are backing up the rpms will drop low when u stop and the car will stall.
