Cant seem to get REDSUPRA's RAF table to work!!
Idle Questions after cam (REDSUPRA's RAF table)
I followed the read-me page instructions and It calculates for about 20 minutes and then says (there is no correct LTIT/STIT data present, please double check your headers and log file)
Whats the deal? I logged only what the read me page told me to log, I turned off fans and A/C, I made sure it was in imperial before i exported. I pasted the data and plugged in my old RAF table. Press calculate, it works for 20 minutes and gets me this error.
Any ideas? Do i need to remove column names first(ie. RPM, STIT, LTIT)?
Can someone take a look at a LOG if I email it to them. I lowered my Set screw so my TPS Voltage at idle is 0.59V. My IAC values are still 160 ish and I can figure out how people get them down to 30-50.
I was just scanning through my tune and I noticed a value under (idle->idle airflow (IAC Reset Park Position)) that was 160. Could this be why I have IAC values around 160? Did I somehow reset something and now the IAC wants to be at 160?
Originally Posted by Black02SS
Its my sheet FYI, . I will adress the other issue I spoke about later today. It was a rough night and I have to get some sleep.
As an FYI, I used both RAF and MAF parts of this after I tuned my VE table and both worked perfectly. Question - How do you estimate the values that were not sampled during a log run?
Thanks for the tuning resource!
