Engine starts, runs 5-6 sec, then dies please phelp
Hi , long time since i have been lurking around here, a friend of mine has a weird problem.
Hot Rod
LS1 Engine and trans
Wiring harness from Street and performance
PCM from Street and performance
Everything was hooked up to an engine with S&P before they shipped it, and it ran fine.
At my friends place, engine starts like a champ, fires right up, runs for 5-6 seconds then stop like you switched off ignition. ???
We use Ease scan and cant see any DTC ?
We also monitor different parametre and can see that injectors shut off after 5-7 seconds, 5.45 ms idling, then just turn them off ????
Anyone that has a clue on where to start ?
What can cause injectors to shut down like that ?
TIA
regards
Rune
Hot Rod
TIA
regards
Rune
Originally Posted by slow
Sounds like the vats system is not disabled.
Ryan
Ryan
But thanks for your input, this will propably (or hopefully) end up with a smple solution.
My friend has struggled over a year, he recieved two wrong sets before they admitted something had to be wrong. with the first set it would never start...
Rune
Hot Rod
TIA
regards
Rune
Hot Rod
TIA
regards
Rune
It sounds like a fuel pump issue. I remember when I was troubleshooting my cars VATS system before and I bypassed it, but I couldn't find the bypass for the fuel pump signal. The pump primed, and the car would start up fine but shut off after a few seconds.
OR the pump is straight up dead?
