HPTuners guys, can carrying over positive trims into PE mode be disabled?
As the title says, can the addition of positive trims in PE mode be disabled. I have been dealing with some quirky issues where my car runs a lot better with slight positive trims than negative trims. I actually noticed this back in my "MAF translator" days too. The real PITA is that positive trims have a tendency to stick. But if I could disable that...
why does your car run better with slight positive trims? tried messing with your O2 sensor switch points to lean the car out with negative trims? It would be an operating system hack to change the PE mode LTFT behavior.
if i didnt sound clear on this let me know, i can get kinda confusing lol
Originally Posted by WS6FirebirdTA00
yeah this is what i was gonna say, try to alter the o2 switch points so that the desired switch point is higher and at the fuel trim reading you want. then it should zero out but use the same amount of fuel as before when it was running good. that should be with the upper cells in those tables. just figure out how many g/sec you are getting at these points and relate that to the cell and change that cell.
Originally Posted by Another_User
I have not seen much in the line of changes after changing O2 switch points. My car does seem to run a hair leaner and better with positive trims, plus they don't go so wacky sometimes. Has anybody had any good results changing the switch points? Can it actually make any significant AF ration difference?
so u want the car to run leaner, hold on let me rethink this lol, ive got a lot going through my head
ok, i get it now, you have + trims and want them to go down because the car runs good now. so u want to lower the switch point like you said. this will make the car inject less fuel to reach the desired setting, leaving it where you are now and running good, sorry i was thinking backwards. so i would drop down the cells 20 instead
i had made changes to this just by smoothing, didnt notice anything bad. as long as your above 451 mV your on the rich side of 14.7 so its safe to just go out and test
