Can Someone Help me smooth out my VE Tables?
If I send you the Bin can you show me how to smooth out the Primary and secondary VE tables?They look like the rocky Moutains right now,But I am hoping that I have finally got my Final LTFT VE tune done!My HP Tuners Version is 1.5 I dont know if that matters?Thanks!
Scott
Scott
Moderator
Scott
Scott
(or plain text) paste-out.
The thing is, you want to decide -which- of the points
deserve to be smoothed -to-. The built-in algorithms
just sort of average things. That's swell, but what you
want is to favor the points you really believe in and
make the unknown ones follow the surface that the
"real" ones define. That's a job for by-hand, by-eye
and bearing in mind the relative "quality" of the points.
Unless they're all of the same or unknown quality.
When in doubt, go richer I'd say; other than idle quality
there's little downside to that. Everything above 1200RPM
I'd err to the rich side, at least. You can always tweak it
more if you don't like the resulting trims.
Thanks jimmyblue.I thought I'd have it wrapped up,my LTFT VE looks good in most spots I have it where I want it.I am -1 to -2 almost across the board to 4000.But there is an area I am having alot of trouble with.1200-2400 20 KPA to 35 KPA.I either get it to +5 to +9 or -4 to -9 I dont get it?Is it my cam at this low KPA causing the problem?
Moderator
That's a very low MAP for a cammed car and I bet
these are deceleration cells? Deceleration fueling
is pretty iffy. Might want to look at DFCO and make
sure it's not contributing to schizoid trimming.
Moderator
I see entry MAP 18, entry RPM 1500, enable speed
18MPH in my stock tune tables; I expect one or more
of these would be jacked to disable DFCO, but I haven't
paid attention to what people are doing, who're doing
it.
it.
