question about start up flare control vs rpm error
Old 06-23-2005, 08:39 AM
WS6FirebirdTA00's Avatar
Default question about start up flare control vs rpm error
what exactly does this table do? im noticing a lot of negative timing and im wondering it its contributing to my low idle levels on start up.
Old 06-23-2005, 01:53 PM
anyone?
Old 06-23-2005, 05:12 PM
technical's Avatar
When you first start the car a decent amount of fuel is dumped into the engine to get it started. That would potentially cause the idle to "flare" up.
The under and over tables for rpm error are used to balance the idle around the desired rpm by adding or removing advance to affect an rpm change. More advance would raise the idle and vice versa.
Old 06-23-2005, 06:01 PM
right now on start up my idle is too low and my timing is about 10-12* when cold and i need to find a way i can fix this
Old 06-23-2005, 07:16 PM
slow's Avatar
there are other reasons why the car flares up at startup, for one, there is no manifold vacuum to prevent this from happening.
Ryan
Old 06-23-2005, 07:48 PM
ok i get what this table does now, i was looking in the wrong one, startup spark correction was what i needed, ill start a new thread for that
Quick Reply: question about start up flare control vs rpm error
