Wiring harness available to run stock gauges/etc with aftermarket engine management
We are now offering a wiring harness that allows your stock PCM to control certain functions. This would be used in conjunction with BS3 or other aftermarket engine management.
It is a complete harness that connects to the stock PCM, and vehicle wiring harnesses. (under kick panel and on top of passenger strut). It is completly plug and play, meaning the connectors that plug into the engine have jumper harnesses integrated that your engine management would plug directly into. (no soldering or splicing.)
All of your stock gauges will work, and your stock pcm would also have-
fan control
fuel pump control
air conditioning
reverse lockout (6-speed)
alternator
Introductory pricing for the harness is $650, and will be available in 1-2 weeks. We have the prototype in our shop car and it is working great.
fan control
fuel pump control
air conditioning
alternator
