HPT and LC-1 not working right...HELP
I can't get my LC1 and EIO working right. I'm not sure if it's wired wrong or what..but i've seen a handfull of threads and i'm still lost..
Here's how I have it wired:
LC-1:
red: connected to 12v source
blue: grounded to chassis
white: connected to EIO black
yellow: not used
brown: connected to EIO white
Green: grounded to chassis
black: connected to pushbutton and grounded
I'm using the LC-1 pid in HPT and it reads a steady 11.39-11.43 no matter what. Doesn't change at all...so what's the deal
SOMEONE PLEASE HELP BEFORE I SMASH THIS LC-1 and EIO WITH A BAT
LC-1:
yellow: not used
Restricted User
LC-1:
yellow: not used
LC-1:
yellow: not used
If you haven't got it working yet, take the LC-1 white and blue and ground it to chassis ground. Take the LC-1 green and put it on the EIO black.
Also, make sure the LC-1 black cannot accidently touch a ground.
2001 pewter told the proper way to do it. That is how I have mine setup, and it works fine. Now, you said it reads 11.4:1 all the time. This is what mine read when I had one wire not connected (it must be a default reading). Double check your connections/splices, I would bet that is where the problem is. I used some crimp connectors and doubled over the wires a couple times because they are such light gauge. You might try that.
