offset table for 42# FMS injectors
Old 08-17-2005, 07:51 AM
WS6FirebirdTA00's Avatar
Default offset table for 42# FMS injectors
just wonding if anyone has an offset table or one that is closer than stock. the tables change a bit just from the 00 to 01 tables. just wondering if noone had a table that was correct if putting the 01 table in would be better or even getting a table for the gm 36#ers?
Old 08-17-2005, 09:24 AM
RedHardSupra's Avatar
https://ls1tech.com/forums/showpost....62&postcount=9
Old 08-17-2005, 09:34 AM
HumpinSS's Avatar
i think he is talking offset vs voltage Red
Old 08-17-2005, 10:30 AM
yeah i am
Old 08-17-2005, 11:30 AM
Rick@Synergy's Avatar
The hard part with this is no one will do the testing. They would have to sit with the injector and flow test at every point and figure out the offset. I have been looking also for the past few years, and have found nothing. Other companies offer them, but because its blue oval, good luck.
Rick
Old 08-17-2005, 11:46 AM
i wonder if a gm table, same style injector would work better if we get one for higher flow rates, at least be closer to it you know? but then again if voltage is constant then would these problems not be resolved in ve tuning?
Old 08-17-2005, 12:20 PM
I think for as far as we all have come with tuning, at this point the offset table will not be the end all to the tuning. I think like you said, with VE, and MAF tables being perfected as much as they are now, that offset table will not hinder us from having great running cars.
Rick
