The rev limiter wont go more than 6400rpm
I have a 2000 camaro A4 and it is tuned with ls1 edit and i opened the rev till 7100 rpm and still 6400rpm is the cut off, plz help me with this problem...
LS1TECH Sponsor
6600 on a 6400 rev limiter isnt completely abnormal...and if your only looking at the stock tach which is inaccurate it just adds to the normalcy of it. Remember it takes time for the computer to see that you've hit 6400...and especially in lower gears your going through rpms at a much higher rate.
