Blown 50 amp ingtion fuse??
This probably doesn't belong in here a 100%, but I figured this would be the best place to get the answer, so this is what we have, the transmission and rear end were removed for modding and are now all back in place, but when I went to fire up the car it blew a 50 amp ingtion fuse I figured it was starter related, but I checked it and it looks like it's hooked up right. The ONly little thing I can possibly think that is wrong (this is a long shot) is that the on small ingtion wire that hooks to the starter there was a star like washer and I couldn't remember if that went on 1st before the cable or not, so it's hooked up....cable, star washer and then nut. I'm lost on this one
FYI, I got it fixed. It was that damn sheild GM puts over the starter that was slightly touching some sodder on the ingtion peg causing it to arc out and blow that fuse.
