Paging Truck guys: PCM Question (PCM Compatibility)
Old 10-31-2005, 10:07 AM
horist's Avatar
Default Paging Truck guys: PCM Question (PCM Compatibility)
I've seen a few threads lately asking about the 5.3/4.8 etc... PCMs ... but I dont' have any first hand experience with them so can't offer a definitive answer..
my question is... w/F-Body's 98 is the only "different" PCM... 99-02 are all similar enough that they can be swapped around...
Is this the same for the truck PCMs? If so can someone provide a break down of the years and engines that use the same PCM?
Old 10-31-2005, 10:27 AM
Black02SS's Avatar
Is there a way to cross check the part numbers and see if they are the same?? I was wondering this as well the other day but got sidetracked.
Old 10-31-2005, 10:31 AM
horist's Avatar
I don't have a truck parts manual but one issue I can see is GM using tons of different part numbers even though they're basically the same... like the 99-00 F-Body PCM is 1 part number, and 01-02 is another, yet they are interchangeable
Hopefully we can get a definitive answer on this... I'll then add it to the stickies as this would be good info
Old 10-31-2005, 10:32 AM
Black02SS's Avatar
I'll do some checking and see if I can't get any info as well.
Old 10-31-2005, 10:39 AM
LS1 Tech Veteran
Steve Bryant's Avatar
Mike,
To the best of my knowledge, all of the 512 kB PCM vehicles from 1999 through 2002 use the same PCM's and many of the same OS. This is true of the 4.3, 4.8, 5.3, 5.7, 6.0 small blocks and even the 8.1 L big block. Activation or deactivation of certain PCM features differ by vehicle as does the parameter values.
I've not seen some sort of officially published cross reference list. However, I'm sure that there are a number of folks who have this information. I would wonder if GM doesn't have some sort of listing like this for use with the Tech II.
Steve
Old 10-31-2005, 11:06 AM
horist's Avatar
^^^ excellent info...
also from another thread
Originally Posted by Zick
What year is it?
For 99-02 4.8, 5.3, & 6.0 the PCMs are all the same and are interchangeable. I would try and find one from a 5.3 though or else there are going to be settings that are different unless your going to get it custom tuned.
03' and up use a different PCM.
I'll add this to the stickies thanks guys!
Old 10-31-2005, 11:57 AM
12secSS's Avatar
Yup, the '99-02 truck PCMs are the same (same part number, prior to being flashed with a calibration file) as the '99-'02 F-Body PCM ... in term of wanting to completely reflash them. The only difference is the BIN file, which leads to a different GM P/N.
