Knock after shift... Any one ever seen it?
Old 10-31-2005, 05:59 PM
SS3520's Avatar
Default Knock after shift... Any one ever seen it?
Changes to the car are, shift kit and 75 shot. Before these changes I had 0 knock. Now I am picking up 3-4* at WOT. I have not changed any WOT settings as far as the tune goes. I am thinking it might have something to do with the shift kit. I did two runs. First was from about 45 and rolled through the gear and let off before the shift (did not spray). I got 3* knock. Second was about 55 - 100 MPH. Car kicked down to 2nd gear and I got 0 knock. Shifted to 3rd and got 3-4* of knock that slowly went down to about 2* before I lifted. This run I sprayed.
I know spraying can cause the knock, but if it were the spray, I would have thought I would have picked it up when I sprayed in 2nd gear. All of 2nd was no knock and 26.5* timing. 3rd had knock and the car began pulling timing.
I am going to pick up some octane booster to see if that helps, but just wanted to check if anyone has had this happen due to a hard shift / shift kit?
Old 10-31-2005, 06:35 PM
bmfcamaro's Avatar
log burst knock on your scanner. it could be tip in knock. what year of vehicle?
Old 10-31-2005, 06:47 PM
SS3520's Avatar
99 what is tip knock?
Old 10-31-2005, 10:30 PM
bmfcamaro's Avatar
do a search you might find some info. "tip in knock"
whoops good catch jimmyblue
Old 10-31-2005, 10:52 PM
Moderator
jimmyblue's Avatar
Tip-in knock is not false knock, it's caused by lean
mixture error. Often from the speed density tune
being off. When you shift hard, you might see a
MAP spike (from the air column against a rapidly
slowing motor, perhaps this is your shift kit doing
its job) which would put you into speed-density
mode by the "unsteady MAP" criterion. If this is
your issue then the logs would show a lean dip in
O2 sensor voltage. Slowing the motor from a place
where MAP was depressed (like by intake tract
restriction at the top end) to where it's maxed
(low RPM WOT) might also trip that trigger.
Old 11-01-2005, 07:04 AM
SS3520's Avatar
My O2s are rock solid at 90-93 so from looking at them, I am getting plenty of fuel. I am going back to my last falsh to see if it goes away. Final question. I am still using edit and autotap to tune. Can you do a SD tune with edit and autotap? From doing some reading, it looks like you need to log dynamic airflow which is not on my autotap as far as I can tell. Many thanks.
