Intermittent Stalling.........
Ok, here is the drill. I always let my car warm up before taking off. Especially in the mornings. But when it first fires up, the idle will vary slightly, kinda goes up and down, enough to notice it, but not effect the warm up procedure.
Sometimes, after I start to drive away, if I push in the clutch and put it in neutral to coast to a stop light, the rpm's will drop to 300 and it will stall. It will fire right back up, but stall everytime. This stalling will happen continuously once it starts until I shut the car off for a while, I can stop driving the car, go into work, come out an hour later, and it runs normal.
I can also effect this if I turn on the A/C so that the car idles faster due to the load.
Any clues as to what could be going on, and how I might fix this. And is THIS the right forum for this thread? I thought you guys would know best...
Funny thing is it dies all 7 times I pushed in the clutch on the way to work this morning. But when I started it at lunch, it ran like a champ and won't do it the rest of the day, only first thing in the morning.............
