LC-1 Software
Old 12-20-2005, 10:56 AM
LS1PWR's Avatar
Default LC-1 Software
Do youhave to use this software when using the LC-1 w/ HPTuners? Also how do you change this:
output of the Wideband side should be set to 1/12 or 1/6th second output-update rate
output of the Narrowband side should be set to 1/6th second output-update rate(best simulate the response of the stock o2 sensor
Thanks
Dave
Old 12-20-2005, 11:06 AM
WS6FirebirdTA00's Avatar
i take it you got that from soundengineers writeup?
Old 12-20-2005, 11:28 AM
ringram's Avatar
efilive is calibrated to work with the LC-1 as it comes out of the box.
If its factory reset, or power cycled etc. No problem it works ok.
Some guys suggest to change the update speed to match stock NB. But mines ok at realtime speed. YMMV.
Old 12-20-2005, 12:53 PM
LS1PWR's Avatar
yeah i did, i used his write up and also made a bx like his but smaller! His setup rocks big time. i got it calibrated and everything but just could not fined anywhere how to chage it.
Dave
Old 12-20-2005, 01:10 PM
Kleeborp the Moderator™
MeentSS02's Avatar
Open up the LM programmer, go to analog out 1, and click on the advanced box. You'll see it under there. There aren't many things you can do.
FWIW, I set mine to 1/6th second, and have a linear output from 11-17 AFR (0-5V). Works great for me.
Old 12-20-2005, 01:17 PM
LS1PWR's Avatar
So i do need to load the software that came with the LC-1?
Dave
Old 12-20-2005, 01:23 PM
MeentSS02's Avatar
Yes...the LM programmer is in that bundle somewhere...depending on when you got your LC-1, Innovate might even have some updates for you on their website. They did a recent LC-1 firmware update and upgrade to their logworks program...
Either way, load the software on your comp and hook up to the LC-1. If you have problems connecting, let us know. Early firmware versions didn't like to communicate very well.
Old 12-20-2005, 01:26 PM
LS1PWR's Avatar
thats the answer i was looking for...thanks i really appreciate it!
Dave
oh yeah i do have the logworks with it!
Old 12-20-2005, 01:56 PM
MeentSS02's Avatar
Cool...I think the most up-to-date firmware is 1.00a or something like that...when you go to connect, just make sure you run from the serial port of your laptop to the OUT headphone jack thingie, and then put the terminator plug in the IN headphone jack thingie, and make sure the unit has power. You can't even open up the LM Programmer unless there is a good communication line from your computer to the LC-1. Kinda frustrating when you are just wanting to know what you can even adjust.
