Bosch Lsu4 O2 Sensor ?
i may be wrong... but I don't think this'll work...
you need a controller to allow the wideband sensor to work... on volkswagons this is built into the PCM... but you can't just go from the sensor direct to a gauge w/out a controller to turn the sensor on and interpret the readings....
Innovate Motorsports makes an LM-1 and LC-1 ... these use the bosch sensor, but also include a controller for the sensor, and provide analog outputs for interacting w/a guage such as the one you posted
LS1TECH Sponsor
It comes with a buffer box ,but I'm starting to guess this is just for "smoothing" out the signal rather than the controller that would be needed to read the wideband signal correctly?
