Jet-Hot LTs + Denso 'vette rears = ...
Moderator
... not enough to keep P1133 and P1153 from popping.
I'm going to have to not recommend the Denso brand
sensors as a fix for the thermal problems. They are
pretty wobbly looking at idle where my stockers with
log manifolds were all happy. Lit, but damn slow, they
look like.
look like.
I too found the densos to apparently run cooler and switch much slower at low loads and idle. The bosch 13111's are indeed a little better but I usually still pop some codes with them too.
Jimmyblue, glad to see you finally threw on some long tubes! Now where's the cam?
My Denso's do the same thing, so I turned the ses light off for those codes, it got annoying seeing it all the time. I got them because my stockers were sucking, but it seems that they are not all that much better. I guess any sensor that is noved from its stock location is going to suck.
Kleeborp the Moderator™
My Bosch sensors took a **** a few weeks ago on me on my Kooks headers. Been running open loop ever since...I'm not gonna go back to closed loop until there is a better solution available. It is too much money to be throwing around at pure conjecture and hearsay.
Location: Live Oak, FL - in the woods where the creatures lurk.
I run the stock (but not original) GM sensors...had 2
heater codes (same O2) in 5 months. Otherwise-all OK.
Have monitored V change with power on (engine off), but
unfortunately it takes ATAP so long to boot.....
Don't hesitate to try out the Bosch 13111's. My self and a few customers have used them with no codes. I have approx 15k on mine, some of it during winter use.
and if so, what year/years vette are these from?
I keep having the 1133 code off and on, usually if I cruise around at low RPM,
but it's done it before even if I do stay on Drive rather than Overdrive.
pat
