EFIlive automatic fueling adjustment?
I read on the EFILive site that it is able to automatically adjust fueling after scanning. Does anyone have any experience with it and does it really work? I would imagine that having that feature would take a lot of the work out of tuning closed loop.
Originally Posted by Black02SS
I do not believe HPT offeres the ability to filter out large transitions in throttle which in turn can throw off the fueling.
Of course we do.
Per the help files:
Histogram Filters
If you define a filter, the filter must return a value of 1 (true) to add the current cell to the histograms data. If the filter returns 0 (false), the frame will not be added to the histograms history.
You can combine filters using AND and OR statements.
Examples of valid filters are:
[SENS.90] > 50
[PID.11.MET] < 85
[PID.11.MET] < 85 AND [SENS.90] > 50
[PID.11.MET] < 85 & [SENS.90] > 50
Enhanced IO Output Triggers
Enhanced IO Outputs Triggers are defined just the same as the Histogram Filters.
Supported Binary Operations
+ Sum up two operands.
- Subtract two operands.
* Multiple two operands.
/ Divide two operands.
^ Raise to a power.
Supported Relational Operations
> If x > y result is 1 otherwise 0.
< If x < y result is 1 otherwise 0.
= If x = y result is 1 otherwise 0.
Supported Conditional Operations
AND If x = 1 and y = 1 result is 1 otherwise 0.
OR If x = 1 or y = 1 result is 1 otherwise 0.
& If x = 1 and y = 1 result is 1 otherwise 0.
Supported Functions
sin(x) Returns the sine of x where x is in radians.
cos(x) Returns the cosine of x where x is in radians.
tan(x) Returns the tangent of x where x is in radians.
abs(x) Returns the absolute value of x.
round(x) Returns the whole number nearest x.
Originally Posted by Super Sport X2
Of course we do.
Per the help files:
Histogram Filters
[SENS.90] > 50
[PID.11.MET] < 85
^ Raise to a power.
Supported Functions
Per the help files:
Histogram Filters
[SENS.90] > 50
[PID.11.MET] < 85
^ Raise to a power.
Supported Functions
Best Regards,
Adrian
Of course we do.
Per the help files:
Histogram Filters
[SENS.90] > 50
[PID.11.MET] < 85
^ Raise to a power.
Supported Functions
Per the help files:
Histogram Filters
[SENS.90] > 50
[PID.11.MET] < 85
^ Raise to a power.
Supported Functions
Below
Sorry, I couldn't help myself....
WTF, the guy asks about EFI and it turns into a Pimp my software thread (Super Sport X2) Frick for what these software packages cost I can't believe you guys couldn't afford to let one get away once and awhile
LS1TECH Sponsor
this was the question...Ken answered. But yet Adrian really let it slide right?
