PE tuning, no wideband, need wideband and dyno guys help
Like the title says. Until I can get to a dyno, I'd like to get my PE relatively close.
I've go the VE table and MAF dialed in. A few questions... What should the PE curve look like? How much (%) more at different rpms? I know you should be slightly richer below peak tq and slightly leaner above, but, how much?
Also, for guys who have widebands, or have dynoed, please post the following:
1. Your PE table
2. Your o2 readings at various RPMS.
I know at WOT you should "shoot" for 890-900 o2 readings, but is that true at 2k rpms, 4k, and above 6k? Or should they read differently at different points?
1. Your PE table
I have my PE table set flat across the RPM range, set at 13.0. Works fine for me. My 02's are around 1075mV +/- a litte bit all across the board. If the AFR is the same all through the range then the 02 readings will be as well.
Tuning WOT without a wideband sucks.
I'm trying to save $$ for a clutch and rearend now. Not sure about the wideband (maybe in the future though).
If I go to a dyno, will 3 passes be good enough to get my A/F right?
Originally Posted by silverTA2002
If your MAF and VE are dead on, shouldn't A/F be pretty close to what is commanded?
At WOT throttle if you have an error between commanded and a properly cal'd Lc1 it will be the MAF that needs to be tweaked... If the MAF is right the numbers will literally fall right on top of each other....
Originally Posted by Phil99vette
Thats correct, the 3-8% fuel corrections are coming in @ part throttle
1. Actually dialing in 14.6 and 12.8 A/F ratios, but having +8% LTFTs.
or
2. Having your LTFTs at -2
The point of my post was to show how inaccurate the stock O2s are. Your LTFT may be -2 but in some cases they are not commanding the correct A/F.
Phil
Phil
Phil
Phil
Originally Posted by Black02SS
I've been saying that for awhile now. Totally agree with you on this one Phil. If you are in need of a wideband, you can pick up a LC1 under 200$ shipped. Pretty cheap insurance if you ask me.
What's involved in installing it?
Ok, so when you guys tune your part throttle VE table with a wideband, what do your LTFTs end up looking like?
