Dashboard in EFI Live
I can't get the dashboard to display anything. It's not even showing the needles that it used to. When i hit the moniter button it goes straight to pause! WTF if going on? How do i fix this?
Mine did that too. I recall you had to reset the default to whichever one you want to use or change to.
Menu>Dashboard>Recall installation defaults
It's been awhile and no way to test since the oval dashboard comes up now for me. I just upgraded and nothing changed, so it appears that if the scanner doesn't get upgraded with the tuner (each have their own builds) the defaults stay the same.
If the above isn't correct, post on efi live. You'll get a quick answer.
I think the path changed between versions. Id suggest that you probably upgraded and the new version uses a different path.
I had that issue. Just copied the files to the other path. But the fix is as mentioned to recall defaults. Post up on the efilive forum you will probably get an exact reply.
I was referring to my version V7.31 (Build 430 - 486). I don't use the program that much so don't recall how it looked in V6.
You aren't on C are you instead of A or B? (Highlight the dashboard tab A>B>C)
There is also a Dashboard tutorial if you installed the manual. Help>Tutorials>Dashboard Customization tool
