Resetting fuel trims
I am finally ready to start tuning my ve table as per the tuning 101 sticky.
When i pull up the menu under vcm controls it won't let me click on the tab to rest the fuel trims....What am I missing??
Mark
Mark
Mark
Mark
The cable says connected...thats why I am puzzled
I went and did a scan and got alot of neg fuel trims in the lower rpm's...I am seeing #'s as high as -15.
assuming I can get the fuel trims to reset, after I adjust the values in the primary vs rpm vs map table do I need to write the calibration to the vcm before I do another scan and log?
You just have to be connected to reset fuel trims. I thought the new version of HPT only had a play and stop button anyway. After adjusting the Ve table, you do need to write that to the PCM, then reset fuel trims again before logging.
