WideBand O2
WideBand O2
is there somewhere that i can buy just the wideband o2 sensor? i'm not sure if you can do it with the ls1s, but i know with the tpi cars you could buy a sensor for i think a honda, and make the box for it and use it to tune the car. i'm basically wanting to wire it in using the egr connector. is that possible on a 98? if someone could give me an insight i would appreciate it. i'm using hptuners by the way. thanks.
I wired a AEM wideband guage through the EGR port, the guage outputs between 0V and 5V, therefore compatible with the EGR input after te EGR is removed.
A little write up is on here:- http://www.hptuners.com/forum/showth...t=Wideband+EGR
