Idles/drives great, but stalls in reverse
Old 08-08-2006, 11:31 AM
SSpdDmon's Avatar
Default Idles/drives great, but stalls in reverse
Car is cam only A4 (stalled) w/ 232/234 cam. Anyone else experience this? Any known fix? RAF & desired airflow are good. IAC's are 60~70 at warm idle. Car goes into reverse ok. But once you start to give it gas and let off, it's starts to surge and stall. Please help if you have any ideas. Thanks!
Old 08-08-2006, 11:50 AM
HumpinSS's Avatar
what do your throttle cracker enable and disable speed look like B4311 and B4312
Old 08-08-2006, 02:47 PM
SSpdDmon's Avatar
They're stock for '00...
B4311 - 2mph
B4312 - 1mph
Also, the throttle cracker airflow doesn't really exceed 0.5 grams/sec since I reduced it by ~50% everywhere. Same goes for throttle follower...reduced by 50% everywhere.
Logically, I wouldn't think it should be anything different than 1st gear. The car doesn't seem to surge that much at all (if any) when you hold it in first. I wonder if it's related to the converter? The car idles currently at ~850rpm, drives great, runs strong, etc. Kinda stumped...
Hmmmmm....deja vu
Old 08-08-2006, 04:04 PM
HumpinSS's Avatar
Check EFILives sit i responded there
Old 08-09-2006, 12:52 AM
GOaT Cheese's Avatar
If it only does it in reverse check for a wiring harness that gets pinched when the engine torques the opposite way. If it only does it in reverse and never in drive that is.
Old 08-09-2006, 08:49 AM
98A4LS1's Avatar
Are the symptoms the same with A/C on or less stalling with A/C on?
Old 08-09-2006, 10:06 AM
SSpdDmon's Avatar
The a/c is removed. Going to try increasing the throttle cracker enable/disable speeds to 10mph/9mph. We'll see....
Quick Reply: Idles/drives great, but stalls in reverse
