what type of hptuner adjustments did you make after your convertor?
is there anything you should adjust before you actually drive it or will i be safe to have a little fun first? i would like to adjust the rpm limit.currently at 6k.i have a hp fuddle 4000 with b and m 24k cooler.thanks for the help guys.
Shouldn't require anything. Eventually, you'll want to adjust your torque converter clutch apply/release speeds. I usually set the first two cells in the 3rd and 4th gear apply tables to 256. This way, it'll prevent the TC from locking up with little or no throttle which can jerk the drivetrain around.
Moderator
You are probably going to have to bring the WOT upshift
MPH down big time to stay off the limiter.
Part throttle tables for shift and lockup want some
tweaking-in.
May as well fix the TCC PWM settings and look at
the General Pressure TCC lockup line-bump value.
Just have to see what it takes for your particular
converter to hold on up to the point of unlock, and
where you want it to unlock for performance /
cruise compromise.
tweaking-in.
cruise compromise.
